mám problém, že keď si spustím hru Minecraft a dám si verziu väčšiu ako 1.7.2 napríklad dám si verziu 1.7.9 sťahuje sa načíta sa mi okno kde je logo Mo....(nechcem robiť reklamu) a okno sa mi zruší. Keď si kliknem dole na lište Windodows ikonku Minecraftu tak v tom launcheri mi vypíše crash.(dole je crash
) Pýtal som sa aj na iných forumoch a tam mi povedali, že mám aktualizovať ovládače ale ovládače sú v pohode teda nie je na ne žiadna aktutalizácia aj tak to nepomohlo čím to je? Pekný zvyšok dňa praje Skajko
Crash
[19:20:52] [main/INFO]: Setting user: SkyHighGamer
[19:20:52] [main/INFO]: (Session ID is token:1337535510N:b10c6af4262145a492bacb7ee036bff1)
[19:20:53] [Client thread/INFO]: LWJGL Version: 2.9.1
[19:20:57] [Client thread/INFO]: Reloading ResourceManager: Default
Starting up SoundSystem...
Initializing LWJGL OpenAL
(The LWJGL binding of OpenAL. For more information, see http://www.lwjgl.org)
OpenAL initialized.
[19:20:59] [Sound Library Loader/INFO]: Sound engine started
[19:21:09] [Client thread/INFO]: Created: 512x256 textures/blocks-atlas
[19:21:09] [Client thread/INFO]: Created: 256x256 textures/items-atlas
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x26c03e88, pid=5440, tid=5836
# JRE version: Java(TM) SE Runtime Environment (8.0_25-b18) (build 1.8.0_25-b18)
# Java VM: Java HotSpot(TM) Client VM (25.25-b02 mixed mode windows-x86 )
# Problematic frame:
# C [ig4dev32.dll+0x3e88]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# An error report file with more information is saved as:
# C:\Users\www\AppData\Roaming\.minecraft\hs_err_pid5440.log
# If you would like to submit a bug report, please visit:
# http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
AL lib: (EE) alc_cleanup: 1 device not closed
Java HotSpot(TM) Client VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
) a tam som niečo klikol aby mi to našlo tie aktualiáacie a vypísalo, že ich mám najnovšie a nie je na ne aktualizácia. Ale skúsim to čo si povedal
