Re: Problém s ENB
Problém s ENB
Poslaťod $Biggie$ » Str 04. Apr 2012 15:10:13
Čau,
dřív na starém GTA mi běhaly všechny verze ENB series, ale teď jsem zjistil, že mi funguje jen jedna jediná verze, chci upgradnout na lepší, ale má to tenhle problém viz. screen, neví někdy v čem je problém?
nastavení enbseries.cfg :
[PROXY]
EnableProxyLibrary=0
InitProxyFunctions=1
ProxyLibrary=
[GLOBAL]
UseEffect=1
AlternativeDepth=0
AllowAntialias=1
BugFixMode=0
SkipShaderOptimization=0
QuadVertexBuffer=0
EnableShaders_3_0=1
AdditionalConfigFile=enbseries2.ini
UseMRTRendering=0
[EFFECT]
EnableBloom=1
EnableOcclusion=0
EnableReflection=1
EnableMotionBlur=1
EnableWater=0
EnableShadow=1
DepthBias=80
EnableDepthOfField=0
[INPUT]
KeyUseEffect=123
KeyBloom=120
KeyOcclusion=121
KeyReflection=122
KeyCombination=16
KeyShadow=119
KeyWater=118
KeyScreenshot=44
KeyShowFPS=106
[REFLECTION]
ReflectionPower=40
ChromePower=25
UseCurrentFrameReflection=1
ReflectionQuality=0
ReflectionSourceSpecular=110
ReflectionSourceTFactor=90
UseAdditiveReflection=1
ReflectionDepthBias=100
UseLowResReflection=0
ReflectionSinglePass=0
UseEnvBump=1
EnvBumpAmount=1
EnvBumpOffset=1
ReflectionFlip=1
[BLOOM]
BloomPowerDay=1
BloomFadeTime=2000
BloomConstantDay=1
BloomQuality=0
BloomScreenLevelDay=80
BloomCurveDay=0
BloomPowerNight=14
BloomConstantNight=0
BloomCurveNight=-7
BloomScreenLevelNight=100
BloomAdaptationScreenLevel=70
BloomAdaptationMultiplier=100
BloomAllowOversaturation=1
BloomMaxLimit=100
[SSAO]
UseFilter=1
OcclusionQuality=0
FilterQuality=0
DarkeningLevel=30
BrighteningLevel=30
IlluminationLevel=30
AdditiveIlluminationLevel=20
UseAmbientOcclusion=1
UseIndirectLightning=1
FadeDistance=100
UseForAlphaTest=1
UseForAlphaBlend=1
UseIndirectLighting=1
[COLORCORRECTION]
DarkeningAmountDay=-3
ScreenLevelDay=60
ScreenLevelNight=30
DarkeningAmountNight=-45
GammaCurveDay=10
GammaCurveNight=10
ColorSaturationDay=-2
ColorSaturationNight=2
UsePaletteTexture=1
[PLUGIN]
WeatherMod=1
[WATER]
UseWaterDeep=1
WaterDeepness=50
WaterQuality=0
[SHADOW]
ShadowFadeStart=40
ShadowFadeEnd=80
ShadowAmountDay=60
ShadowAmountNight=60
ShadowScreenLevelDay=60
ShadowScreenLevelNight=60
ShadowQuality=2
UseShadowFilter=1
FilterQuality=2
ShadowBlurRange=30
[ENGINE]
ForceAnisotropicFiltering=1
MaxAnisotropy=16
ForceDisplayRefreshRate=0
DisplayRefreshRateHz=60
[MOTIONBLUR]
MotionBlurQuality=1
MotionBlurVelocity=40
MotionBlurRotation=40
[PERPIXELLIGHTING]
SpecularColorMin=0
SpecularColorMax=100
SpecularColorMultiplier=100
SpecularGlossinessMin=0
SpecularGlossinessMax=5
SpecularGlossinessMultiplier=100
[DEPTHOFFIELD]
DOFQuality=0
DOFNumberOfPasses=5
DOFFocusRange=300
DOFBlurinessRange=7
http://www.youtube.com/user/NotoriousVG
Již neaktivní hráč známý pod nickem ''The_Notorious_B.I.G''. V tuto dobu pouze už jen APB:R (;
$Biggie$
Registrovaný: Sob 23. Apr 2011 17:11:05
Re: Problém s ENB
Poslaťod F!r*tMn » Uto 01. Máj 2012 16:11:08
1.Odstran ENB, spust GTA, a zkontroluj zda je to v pořádku.Jestli ano,vrať tam ENB series
2.Jestli to není pořád v pořádku,při hře stiskni klávesy ALT+ENTER(gta bude v okně),pak dej zase ALT+ENTER.
3.ani to nepomohlo?
Zkontroluj zda máš aktuální ovladače grafické karty
[color=blue][size=110]
My evolution :
[color=red][b]1MenuX1 > MrSecond > [color=green]FirstMn
F!r*tMn
Registrovaný: Pia 06. Apr 2012 20:14:24
Re: Problém s ENB
Poslaťod $Biggie$ » Uto 01. Máj 2012 17:30:53
Problém jsem už dávno vyřešil, pomohlo mi jedno forum, stačilo stáhnout starší d3d9.dll .
$Biggie$
Re: Problém s ENB
Poslaťod NuSo » Uto 01. Máj 2012 23:07:52
Fajn, zamykám.
