Re: Nejde mi spustit hra
Poslaťod Ryso » Uto 20. Sep 2011 12:09:32
Zapnem samp, napojim sa na hociaky server, nabehne mi to uvodne logo a potom mi crashne hra.
Skusal som 3x reinstall (gta aj samp), zakazdym som nainstaloval do inej zlozky, hladal som na nete vsetky mozne rady, stale nic.
SA-MP 0.3c-R3
Exception At Address: 0x004DD5A3
Registers:
EAX: 0x00000032   EBX: 0x00000000   ECX: 0x00000000   EDX: 0x773B6344
ESI: 0x00B6BD44   EDI: 0x00000001   EBP: 0x769E7E90   ESP: 0x0022FCCC
EFLAGS: 0x00210293
Stack:
+0000: 0x00000001   0x0000000A   0x769E7E90   0x00000000
+0010: 0x0022FCEC   0xBF800000   0x00000000   0x00000000
+0020: 0x3F800000   0x00000000   0x00000000   0x00000000
+0030: 0x3F800000   0x00000000   0x02012B98   0x00000024
+0040: 0x00000000   0x00000000   0x00000000   0x00000070
+0050: 0xFFFFFFFF   0xFFFFFFFF   0x769F881F   0x769F88C9
+0060: 0x773B6230   0x00000001   0x00000000   0x00000000
+0070: 0x0022FCF8   0x001E0502   0x0022FDA4   0x76A462E3
+0080: 0x5767521A   0xFFFFFFFE   0x769F888D   0x769F89B5
+0090: 0x00000000   0x769F914B   0x769F9180   0x0022FE1C
+00A0: 0x00000000   0x00000000   0x00000000   0x00000003
+00B0: 0x01FD5888   0xBDCCCCCD   0x3F800000   0x00000000
+00C0: 0x3DCCCCCD   0x3F800000   0x00000000   0x3DCCCCCD
+00D0: 0xBF800000   0x00000000   0xBDCCCCCD   0xBF800000
+00E0: 0x00000000   0x0022FF78   0x0083BF3B   0xFFFFFFFF
+00F0: 0x00507424   0x00000032   0x00000000   0x3F800000
+0100: 0x00748CFB   0x75B02877   0x00000000   0x0022FF88
+0110: 0x7FFD5000   0x01760000   0x00000008   0x01761130
+0120: 0x00000008   0x00000100   0x00000008   0x00000102
+0130: 0x43C80000   0x43960000   0x00000000   0x00000000
+0140: 0x00000320   0x00000258   0x00000000   0x0022FE54
+0150: 0x001E0502   0x00000200   0x00000000   0x01A601F6
+0160: 0x00C0D5B9   0x000001F6   0x000001A6   0x0000002C
+0170: 0x0022FE2C   0x00825EA4   0x75B02877   0x00000000
+0180: 0x7FFD5000   0xFFFFFFFF   0x00821D17   0x00000065
+0190: 0x00000065   0x0022FF88   0x008246F1   0x00400000
+01A0: 0x00000000   0x018B2636   0x0000000A   0x00000094
+01B0: 0x00000006   0x00000001   0x00001DB0   0x00000002
+01C0: 0x00000000   0x00000000   0x00000000   0x00000000
+01D0: 0x00000000   0x00000000   0x00000000   0x00000000
+01E0: 0x00000000   0x00000000   0x00000000   0x00000000
+01F0: 0x00000000   0x00000000   0x00000000   0x00000000
+0200: 0x00000000   0x00000000   0x00000000   0x00000000
+0210: 0x00000000   0x00000000   0x00000000   0x00000000
+0220: 0x00000000   0x00000000   0x00000000   0x00000000
+0230: 0x00000000   0x00000000   0x00000000   0x00824588
+0240: 0x00000000   0x00000000   0x7FFD5000   0xC0000005
+0250: 0x00000000   0x018B2636   0x00000044   0x018F3708
+0260: 0x018F2590   0x018F0C00   0x00000000   0x00000000
+0270: 0x00000000   0x00000000   0x00000000   0x00000000
SCM Op: 0x0, lDbg: 0
Game Version: US 1.0
Vie mi niekto poradit?
Ryso
Registrovaný: Pon 17. Máj 2010 17:59:02
Poslaťod Guminator » Uto 20. Sep 2011 13:15:01
Niesom žiadný odborník ale niečo podobné mi robilo ... a tiež som reinstaloval gta a aj samp a nič .... tak som si stiahol nové GTA a išlo to hned ... inak maš asi US verziu tak si skus stiahnut EU .... je to len mooja rada či to pôjde neviem .... Ale mne to išlo,... a inak pri preinstalovaní si aj vymazal zložku z Mojích dokumentov ?
Good Luck
Guminator
Registrovaný: Pon 17. Jan 2011 17:04:20
Poslaťod NuSo » Uto 20. Sep 2011 14:15:55
Treba zamazať všetko: hru, savy, hudbu. Proste všetko čo sa priamo dotýka San Andreas. Nech ti nič nezostane okrem inštalačky.
Poslaťod Ryso » Uto 20. Sep 2011 14:20:43
To uz som 2x spravil. Teraz taham 3 rozne verzie gta. Snad aspon jedna z nich pojde :D Istota je gulomet.
Ryso
Poslaťod Velbloud » Uto 20. Sep 2011 14:53:09
Nebo se pohrabat v registrech a najít zbytky po GTA. Tohle mi zachránilo krk už několikrát. Případně použij nějaký program typu CCleaner.
Víťaz Netopeer Awards v kategórii - Osobnosť roku 2013 a 2012
Velbloud
Homosexuál
Homosexuál
Registrovaný: Štv 24. Dec 2009 11:28:01
Poslaťod PumaSk » Uto 20. Sep 2011 15:50:56
Ja som si prave CCleanerom pokazil pc :D som cistil registry viac krat za den a nakoniec po restarte mi neslo nic...
PumaSk
Poslaťod Velbloud » Uto 20. Sep 2011 16:57:54
No, proto to bude lepší vyčistit manuálně.
Velbloud
Homosexuál
Homosexuál
Poslaťod jacky32 » Sob 24. Sep 2011 8:22:14
toto mi taky dělá na PFR v3 a reálných zemích:-/
Víťaz Netopeer Awards v kategóriách - Hráč roku 2013 a Hláška roku 2013.
jacky32
Registrovaný: Štv 14. Jan 2010 16:56:57
Poslaťod NuSo » Sob 24. Sep 2011 20:49:08
Jemu ale absolútne nejde hra.
Poslaťod Suveren » Ned 25. Sep 2011 12:08:07
Nebo zkus obnovení systému, může to být i chyba ve windows.
Suveren
Poslaťod Premium » Ned 25. Sep 2011 12:20:25
Ahoj, tento problém sem měl taky, zkoušel jsem uplně vše a nic nepomohlo až toto.
http://www.stahuj.centrum.cz/utility_a_ ... installer/
Pomocí toho odinstaluj GTA, a pak jen nainstaluj
Premium
Registrovaný: Uto 27. Júl 2010 13:14:38
Poslaťod Ryso » Sob 01. Okt 2011 10:22:10
Ten revo uninstaller funguje, uz mi ide SAMP.
Dakujem Premium.
Ryso
